Hello everybody
I just would like to know if somebody out there has smaller problem like what I have .
I just bought nokia (n95 -159 Rm) from ebay as new -now I up date the software once after I up date it.
For some reason I rest my device be typing *#7370# and *#7 .… codes . now I up date my phone
A gain But I find this problems coming up
1-sometimes when I switch my phone off the screen go blank black (but u can see there is light on the back ) and the top keypad lights don’t go off.
2-I switch it off sometimes it report itself again .
3-sometimes switch off perfect.
4-somtime if I do set the clock and date after been switch on (not from screen beginner )the phone freeze and then report it self again .
I have no ideas why the phone behave like that’s
Pleas Note-all the phone appellation working perfectly and no problem’s .
Any help please
It can be a Hardware issue . In case you want to get rid of corrupted software , you can do the Vulcan Death Grip and/or reformat the memorycard . Be aware to have a backup of all your personal data : they will be lost ! Nokia default code = 12345 . See this thread :
http://www.allaboutsymbian.com/forum//forum/thread/81021/
😊 Regards jApi NL
jApi NL wrote:It can be a Hardware issue . In case you want to get rid of corrupted software , you can do the Vulcan Death Grip and/or reformat the memorycard . Be aware to have a backup of all your personal data : they will be lost ! Nokia default code = 12345 . See this thread :
http://www.allaboutsymbian.com/forum//forum/thread/81021/😊 Regards jApi NL
Hello Japi NL
And thank you for your help but its seems this did not work as well.
I like to have your opinion for this one please -I had been remove the phone back cover and I fond that’s there is a blue nick righting on (the top inside phone -up the camera )do u think this is normal
Or the phone has been repaired ???
I also find that’s the wlan number on the box are different on the phone like( on the box-0022fc29e163-on the phone 001c9A3843f6)dose this make any different on the phone ???
cheers
It seems like the software on your phone is hacked or reflashed ? I cannot help here very much , but most of your questions could be answered by the vendor . I'll give you some threads .
When you like to reflash your phone ( I never did !) , you can read a How To here : http://www.allaboutsymbian.com/forum//forum/thread/64399/
For product code of N95 :
http://www.allaboutsymbian.com/forum//forum/thread/58225/
Nemesis you can also use to check if the product code of your phone is equal to the code on the sticker below the battery .
That's all I can do . Everything at your own risk . Good luck
😊 Regards jApi NL
Thank you for your help .I will try do this things soon and I will let u know .
Best regards
