Problems with Podcasting
5 replies · 2,199 views · Started 13 September 2009
I'm currently having problems with my podcasting serivce. It was working the other week, now all of a sudden when I try to update my podcasts, it says updating then all of a sudden goes back to update needed with a "!" next to it. Has anyone else had this problem? I've searched all over the place and can't find any answers
Just checked mine and they all worked apart from the Lost one has the same issue you said, but that's because there's no content on it until the series starts again in January..
Which podcasts do you subscribe to, see if anybody has the same issue with the same podcast.
I've got
Best of Chris Moyles
IGN.com - Three Red Lights
Scott Mills Daily
Lost
TWIT
one of mine is the chris moyles one but i've not had that for a few weeks. Which network you with? If possible, can you type up your settings so I can see if changing mine to the same will work?
still getting a http header returned with error. Not sure whats going on with it! Will probably phone Voda and enquire tomorrow
Factory podcasting on S60 5.0 is a trash. I had to repair it several times. I gave up and looking for an alternative....
