n95 screan upside down and flashes on not often
1 replies · 3,932 views · Started 14 September 2009
Hey, dont know if you already found a solution for your problem, but i had the same and i fixed it by replacing my slide cable, and he you still have your warranty it should be something they can fix for you at the nokia case center.
