Operator logos
13 replies · 2,587 views · Started 10 March 2003
Does anyone know of an app for the 9210i (or pc software) i can use to load operator logos i have saved on my mmc/phone? without having to send it to myself? Logomanager (1.29) does not seem to want to connect to my phone 😞
Is the Celesta MyStyle that allows you to send Logo operator to Phone without using SMS.
http://www.allaboutsymbian.com/software/directory/viewsoft.php?id=272
[quote="TheSpecialBoy"]Is the Celesta MyStyle that allows you to send Logo operator to Phone without using SMS.
http://www.allaboutsymbian.com/software/directory/viewsoft.php?id=272[/quote]
Will this app interfere with the Psiloc EMessaging I have installed? I think I read somewhere (most likely here I think) that it does.
If you have emessaging than you can send operator logos to yourself already!!!!
I use emessaging to send operator logos to myself.
[quote="Dazler"]If you have emessaging than you can send operator logos to yourself already!!!!
I use emessaging to send operator logos to myself.[/quote]
Does this mean you actually send an sms message via the network (that you pay for - well we do anyway) just to have it come back to your phone? Or can you actually just load it using the app onto your phone? I don't want to pay for an sms every time I change my logo (which can be a couple of times a day sometimes).
Or you buy a mbus cable and use logomanager.
Or you sent yourself an sms every time with the new logo. Which I aggree is so stupid, but It's the only way without the extra hardware :s
This is why trial versions are usefull.
I use psiloc emessaging reader--free afterall, and for logo I use Celesta MyStyle.
I suposed I am attached with these guys since 9110.
But in terms of payments, You will pay the 0.07 USD per message or so, each time you change your logo 😃
So there is no app that I can use to load logos stored on the phone? I either have to sms myself or use pc software like logomanager? That sucks.
[quote="Matai"][quote="TheSpecialBoy"]Is the Celesta MyStyle that allows you to send Logo operator to Phone without using SMS.
Will this app interfere with the Psiloc EMessaging I have installed? I think I read somewhere (most likely here I think) that it does.[/quote]
Can you at least try it? 😉
[quote="TheSpecialBoy"][quote="Matai"][quote="TheSpecialBoy"]Is the Celesta MyStyle that allows you to send Logo operator to Phone without using SMS.
Can you at least try it? 😉[/quote]
Hi Special,
Thanks for the recommendation. Installed MyStyle which sends the logo to the phone :|. However now I don't get a msg tone to indicate an incoming message. Please help 😊
I'm confused doesn't mystyle use an sms 2?
Would be stupid to buy MyStyle if you already have emessaging while this could do the same thing wouldn't it ? 😉
[quote="Dazler"]I'm confused doesn't mystyle use an sms 2?
Would be stupid to buy MyStyle if you already have emessaging while this could do the same thing wouldn't it ? 😉[/quote]
No I'm afraid I was mistaken. MyStyle DOES load the logo to the phone without sending an sms, so my problem is solved. Thanks guys. It loads it to the phone then saves the msg in drafts which you then just delete without sending. Cheeers 😊
