Calling all experts!!!Help or advice!!!
4 replies · 5,419 views · Started 15 September 2009
Hello all,
Can any one help or give advice about my situation..
Ive got a n95-1 that a friend gave me ,screen didnt work..
So i got one off ebay fitted it ..
now i get blank white screen..
All the noises can be heard buttons work camera even works..
So i read about this problem..
Some say could be compatibility issues update phone from nsu..
i try that but with no screen it hard..
I get my pc to recognize phone in off line mode and nokia pc suite sort of starts happening..
But then asks me to put sim card in to start update ..
my o2 sim dont work in it....
Gutted
Any one know what to do or have a suggestion
Try the nokia repair point website is mucking around dont load the local area!!
Please need some advice...
Thanks in advance
cable .. you might see if you still have a display problem.
if a hard reset / flashing the firmware doesn't help then I think a visit to the service center is best. At least they can give you a quick assessment of the problem.
Good Luck!
yeah the hard reset option hasnt` solved the screen issues , in regards to the tv out suggestion, i have tried to hook up tv but to no avail ,was thinking that maybe in offline mode the phone isnt able to output to tv or the option might have to be chosen on the settings and with no screen it`s impossible . any clues with the screen compatibilty maybe the wrong lcd display been fitted although the display says it for n95-1 . any more advice really welcome..
thanks again
i have tried replace the slider mechanism no joy another screen no joy .. running out of ideas here . i have also tried plugging in tv no joy however may not have correct lead ,
Does any one know about the circuit board ,what is the display chip inside..etc
really appreciate all the replies ..
thanks
