Hi, I'm having an annoying problem with my N96 in that I can't use the 'save to contacts' option when viewing calls in the call log.
I got a call from a friend on a new number so after the call I went into the call log, found the received call and chose 'save to contacts', 'update existing'. It delays briefly (like the N96 always does between programs) before jumping back to the main screen.
I've used Jbaktaskman to see if I can see what app is opening (in case it's set to kill when sent to back) and it briefly flashes up Pbk2ServerApp with the contacts icon, but I'm not fast enough to check the program rules before it disappears.
This is a fairly recent problem as it was fine a month or two ago, which makes me wonder if it's been caused by either Jbaktasman settings or installing another app.
Is anyone else suffering from this? Any advice on how to fix it?
Finn
