moonshot wrote:I am not happy with Nokia because I bought my 5530 after reading all the spec. here...... http://europe.nokia.com/find-products/devices/nokia-5530-xpressmusic
Reading this page it indicates that the 5530 does 'come with music'. After searching the box for the code to enter on the 'come with music' site I contacted Nokia and was told I should have read the page correctly.
I will give the 'come with music' gimmic two years and then Nokia will stop it. So those who have downloaded all the free stuff will be ok until their handset needs replaced.
Moonshot,
Nokia "Comes With Music" phones are not ONLY available as a CWM bundle. They are ALSO, and more COMMONLY available WITHOUT the CWM element.
Indeed, the 5800XM, is also a CWM device. But on most of the UK nets, it is offered as a STANDARD normal handset only instead, WITHOUT the CWM bundling service.
And on the very page you refer to in your links, as much as it's described as a CWM phone (because in effect, it is, it is one of the select range of handsets Nokia have chosen to offer as a CWM service, as well as a normal handset package), then if you click the Full Specifications link, it tells you the box contents are:
* Nokia 5530 XpressMusic
* Nokia Battery BL-4U
* Nokia Travel Charger AC-8
* Nokia Short Connectivity Cable CA-101
* Nokia Stereo Headset WH-205
* Nokia 4GB microSD memory card MU-41
* MiniDVD
* User GUide
No mention of the CWM Activation card there, and that's from the page you refer to.
And moreover, at the footnotes, it makes it clear that:
"The availability of particular products, services and features may vary by region. Please check with the Nokia dealer nearest you. These specifications are subject to change without notice."
In other words, you are getting slightly misconstrued as to what your phone actually is.
You have a 5530, which just happens to also be one of the handsets that is ALSO available, if the Operator wishes to offer it, as a CWM Package too.
But it doesn't mean that it HAS to be a CWM package. And like I said, in most instances, they are not.
Hope this helps, and leaves you feeling much happier that you have not been in any way ripped off mate.
