Short links / hot key's
8 replies · 6,887 views · Started 17 September 2009
Hi Dirkjan . What is Quickrun and where do you use it for ?
I remember my Quickrun from 1956 . It was an excellent product . After a long morning ride I was looking eagerly for a nice lunch though ! To reload my "battery" .
Now it is old and rusty : http://www.rijwiel.net/junquicn.htm
😊 Regards jApi NL
Hoi jApi
In that year I was only one!
By quickrun you can define your keys to activate an app or open a document or even to do an operation, such as reboot, change profile, call predfined number,go to inbox, lock the keyboard,etc
I do not know that application and I wonder if someone has already used it.
For almost all your wishes , I use JBakTaskman Applicatonmanager from our Russian symbian friend Juriy Bakunin .
It has many shortcuts from 1,2,3,...,0 and a,b,c,......z . All different apps and also App + File .
Or by pressing # or space you see al your apps in a row . Fast selection by entering e.g. ga for Gallery , etc .
When Taskman is open , you find it by Longpressing menu key . The interface can show amount of RAM , C: and E: disk space . Also Clock with hr/min/sec and date . It is free and in many languages (Dutch)
http://jbak.ru/jbaktaskman_en.php
http://jbak.ru/griffon2.php
Griffon2 is a very speedy Filemanager , found on the Russian page
😊 Regards jApi NL
JBakTaskman is a neat application, which I discovered after buying Cute Keys.
Cute Keys allows me to launch applications with two key combinations, for example, CTRL and M launches Google Maps. With JBakTaskman I could do the same (long pres menu, then M).
