ovi store problem
4 replies · 2,560 views · Started 17 September 2009
Am i missing an Ovi store update? These days whenever I look at Ovi store it seems to take forever to load, error messages, loading for ages etc. Or is Ovi just a bit crap at the moment?
I'm having the same problem, I uninstalled it and am currently using the ovi website as it is a much easier experiance.
I've been wondering...every since v12 firmware upgrade and a factory reset and reinstallation, Ovi Store and Handango InHand software don't full work.
Handango's won't let me buy anything.
Ovi Store will browse for a little bit then just go off into the wild blue yonder and stop responding.
Best bet is to browse on the PC and then download to the N97.
Besides, InHand doesn't give you a Trial download option, it wants you to buy it right off.
I'm having the same problem. Ovi Store just seems to be a bit busy at the moment.
And it couldn't happen at a worse time. Nokia have started advertising the Ovi Store on the telly.
