NE song you want as ringtone !!!!
4 replies · 2,721 views · Started 22 April 2002
just play the song or tune you want on ur stereo and record it using ur voice recorder. then goto profiles- ring tone select browse and then select the file you saved the song too.
You can have ne voice/ song you want as ur ringtone !!!
BTW you dont have to send me ne cheques in the post for this nice idea... can drop me an email -
[email protected][email protected]</a>
i think we wont send you a cheque cause
we already knew that $-)
Better than shoving it in front of a speaker, shove a CD into your PC, record a bit of a song into a WAV and whip it over the serial line and voila!
Is this illegal?
Yes, it must be serious because it's an issue that has even been featured on Radio4!
I don't know what all the fuss is about, it's just as easy to which a cable from Line Out on a HiFi to Line In on a soundcard. The reduction in sound quality must be so neglibable.
There must be more to this copy protection racket than meets the eye.... as long as they don't do this silly protection on DVDs - that would make me upset.
