help - mrouter crashes
9 replies · 3,217 views · Started 10 March 2003
i installed pc suite (from cd and ver 1.1 fren se web site)
after reboot
mrouter wouldnt start giving am error msg;
could not create capabilies manger
then it exits
cannot sync, backup etc
please help
This SW makes active sync look good. Managed one sync, since then nothing.
Windows XP
Dell 8100
I had the same problems too!
I solved it by starting my PC WITHOUT phone in the craddle.
Only after everything has started up. I put the phone on the craddle &
everything works OK.
Not really very smooth... but it works!
[quote="mdjvz"]I had the same problems too!
Not really very smooth... but it works![/quote]
just tried that, still the same thing
even rebooting without craddle connected gives same error msg
could not create capabilities manager.
When my phone is not in the cradle pc is so slow, until i put the phone in cradle but found a way around it, now when phone is not in cradle i uncheck connect to phone via usb in mrouter's properties.
I have the same problem except that it doesn't matter wheter the p800 is in the cradle or not when I boot my pc, but after 3 times putting the phone on the cradle mrouter chrashes....
strange.....
I use IR rather than cable connect, but always got the "cannot create capabilities manager" message on booting, until I un-installed and re-installed PC Suite.
[quote="Anonymous"]i installed pc suite (from cd and ver 1.1 fren se web site)
after reboot
then it exits
please help[/quote]
I was having this problem too, and stupid Sony Ericsson tech. support was ZERO help. After much experimentation I ran "regme.bat" which was in the <install_path>\Sony Ericsson\Mobile directory. As soon as I ran that, everything started working perfectly.
