Okay, i've had my 7650 for just under 5 months now, and its developed a few interesting bugs.
A) The slider doesn't lock in the up position
B) The keys on the right hand side are getting tempremental, and
C) The thing is SOOOOO sloW!
I've taken it into my local NSC to get it all fixed, n they are doing it all free! New firmware, new rails and keys that WORK.
So now to my point, what CAN i do it 4.xx that i couldnt do it 3.12?
PEACE OUT
T
You should notice a dramatic speed improvement, and it should be a lot more stable.
No added capabilities as such (unless you count added 3 extra colours to the pallette as a capability and you should be able to change your oplogo if you couldn't before).
Quite a few people have the slider issue I think? Haven't seen a solution for it. Also, I've had my current 7650 for about 4 months and notice the 0 key (space) seems to do double presses (so I end up with a 0 instead of a space) even though I'm only pressing it once. 😞
evobit,
My "0" keys doing the same thing, had my phone since september '02.
Glad mines not the only one! 😉
Yeah, I'll be taking my phone in before the end of warranty to see if I can get issues like the slider and 0 key sorted out 😊 My warranty ends september this year (I've already had the phone replaced once -thats why I said 'current' handset)
