Nokia web browser
1 replies · 2,935 views · Started 22 September 2009
I have two Noika N95 8GB mobiles,i took the backup of one nokia mobile in my PC and update that backup on Nokia another mobile phone and after that i found that Nokia web browser doesn't show all content properly,for example when i open the web site mail.yahoo.com and then i try to enter the user name and password,i found no window come to user and password and i enter user & password on the site and found the moving character but in blank state.
How do i reset my web browser?I had already enter the code *#7370# for factory restore and also upgrade the firmware (V 31.0.015),but problem still same in the Nokia web browser.
Would you please advice about to reset the Nokia web browser?
I don't know the specific issue about Yahoo , since I don't use Yahoo . I have a similar issue with Google Mail . After entering username and password it ends up in a blank page ........!
There is two things you can do . The second is probably the best :
1) Open Web > Options > Settings . Check a/o Change .
2) The solution , that works for me : install the fast and reliable Opera Mini 4.2 http://mini.opera.com/ and try the same thing .
After some learning period , I almost don't use Web anymore .
There is also the new Mini 5 (beta status)
Another fast webbrowser is Skyfire : http://get.skyfire.com/m
😊 Regards jApi NL
