can i sync my E75 with MS Outlook via Bluetooth? if so, please advise how to set this up.
ive been trying several times but cant get the E75 to connect to the PC via BT.
please help. thanks!
eliew
eliew
Hi.
You can install Nokia PC Suite from nokia.com/pcsuite, once you install Nokia PC Suite, you can connect your phone using Bluetooth and try to sync your device with Outlook using Nokia PC Suite PC Sync.
