Text sending not working
1 replies · 3,072 views · Started 23 September 2009
Anybody know why phone wont send reply to a text msg. Doesn't even go into the out box just fails to send and gives error msg eventually. Also keeps coming up with message centre option which of course is not what I want to use and is not set up.
Text msgs come in okay but won't go out! :frown:
Some more info please ! Does this happen from the start ? Did you check the settings in Messaging > SMS ? Did you ask your Operator/Provider for the right settings ?
😊 Regards jApi NL
