Nokia N97 Loose Part?
3 replies · 2,169 views · Started 23 September 2009
Hey everyone, I Notices something loose in my nokia n97.
I shaked the phone with slider close I hear something inside moving around but when I slide it up and shake it there no sound. It has not effect the phone yet but I sure it not good ethier. Anyone Know what wrong?
I have drop it a few times but nothing big. youtube of nokia n97 drop test and it turn out ok.
Thanks For everyone Time
mine does this aswell, not sure if it effects anything. my best guess is something to do with the slide mechanism as it only does it while closed
I have the same issue but i think it is, as mentioned above, something to do with the hinge mechanism. On the left hand saide of the screen, the hinge has an extra stability leg so this could be whats rattling around with the screen closed. Im guessing this is the prob as it comes from the top of the handset when it is closed in portrait and, of coarse, it doesnt do it with it open. Ive tried to hold the slider switch, battery etc whilst shacking it about and that is all i can think of tbh.
-Des
