is it possible? i cant find any way of getting a 2nd widget on the homescreen
i wanna have 2!
i wanna have 2!
As far as I know, you can only have 1 on the home screen.
This sounds like a job for...
DAAAAAAAAAVVVEEEEEEEEECOOOOOOZZENNNNNSSSSSS!!!!
lol, i did consider putting a widget together but the problem is I might only be able to receive from my server and not necessarily send... depends on settings on mail server...
pop3 mail is pretty straightforward, though... but it would be pull, not push...
So, before I run off and do something, what would be the email widget wishlist?
Hi Dave
I have both aol and bt email addresses so I do not know about the imap server but the aol address works fine in default email widget.An option for headers only would be good if possible.My current problem is that the retrieval settings on bt mail box change\return to disabled when I sometimes disconnect from network - I have not pinned down yet - anyway a widget that keeps the same settings would also be nice as well.
Boothy
PS not being cheeky - how are you with python ?- could you fix problems Argh was having with his HDR script over on the N95 forum?
Python not my bag I'm afraid...
Thanks for all your contributions anyway
Boothy
maybe just ONE widget that scrolls through your emails
screen 1 - RoadSync
fade out
screen 2 - gMail
fade out
screen 3 - whatever other pop/imap
fade out
screen 1 - RoadSync
oh you get the idea
ram consuming it don't matter! want more!
just want different desktops where i can set my HOME and WORK screen, like the E series phones =(
go for it, that sounds pretty awesome 😃
Hi
I installed profimail on my N97, and that allows you to have it as a widget on the homescreen with multiple accounts.
Regards
Gary
gary, does it cycle through the emails as per my above post? or does it just throw everything into one window, no distinction?
Hi Jerm
It has one window that tells you what is unread in each account. Am still getting used to it myself.
Hope this has been of help
Regards
Gary
cool...
so it shows unread, and no preview, right?
i'll give it a go, thanks!
still want multiple desktops boohoo
Dave!
First. Congratulation for your work. Nokia should pay You for this what You do for N97😊
Second. OnIf You can add on Your news widget a MOBILEBLOG.IT. Is a good site for mobile news.
Third. My widgets on mainscreen don't work. All the time connecting.
Milko
just tried the trial...profimail doesn't support OWA =(
