Is it possible to cut and paste text when in the default messaging application?
Cut/paste on N97
Yes, use the virtual T9 keyboard, select the menu icon (three vertical lines) and you should find cut, copy and paste there.
It may be available in some places with the keyboard 'open', but it's always available when the keyboard is closed if you use the virtual T9 keyboard.
I've found you drag your finger (or stylus) over the text to highlight and get get a little pop-up to prompt to copy.
Yes, ditto, although only used it now and again when in messaging mode, with keyboard out, but simply highlight the text by dragging your finger across, and the prompt comes up asking you to copy. Press ok, then when in the new message, click on options, click editing options and then paste.
Are are any keyboard shortcuts anyone knows of? Ctrl C and Ctrl V equivalents?
nottmbantam wrote:Are are any keyboard shortcuts anyone knows of? Ctrl C and Ctrl V equivalents?
Nope, the 5800 didn't have a keyboard.
