N73 Screen Problem
2 replies · 4,246 views · Started 25 September 2009
Hi, I have searched loads of forums for a solution to the problem that I have with my Nokia N73. After the phone has been a while and I unlock the screen to receive a call or to play a game etc I get a screwed up screen where you you have to take the battery out and start again. I changed from the standard UK firmware to the Europe Music edition firmware to see that would help and also tried Soft and hard resets but none would work.
I have attached a pic of the screen and am hoping someone can tell me whats going on with my phone.
Thanks All Will
Attachments: 05092009167.jpg
When hardresets / firmware reinstalls don't solve the issue , it will be a hardware issue . Like moisture , bad connector or screen damage .
😊 Regards jApi NL
jApi NL wrote:When hardresets / firmware reinstalls don't solve the issue , it will be a hardware issue . Like moisture , bad connector or screen damage .
😊 Regards jApi NL
Thanks for the info. It only does it a few times then I don`t see if for ages then it`ll start happening again. Nevermind I have a 5800 now but I really liked that phone and now that my daughter is using it gets frustrating when the screen goes like that.
Wull
