Nokia will in a couple of weeks realese a new software for the Nokia 7650 and 3650. With this new software, u would be able to record video and sound. It will be out on the Nokia.com in a couple of weeks and FREE.
I read this on www.mobil.nu
Nokia +new Software
My Swedish is a bit rusty...
is that an app (download from nokia.com & install via PC suite), or is it part of a firmware upgrade?
Paul
Its an installable app, thats gonna be available from nokia.com in a few weeks.
Reeks of Hantro... :roll:
It's the second time I see this piece of news floating around these forums.
Is there anything OFFICIAL about that? Well, it would anyway VERY nice if Nokia will make us this big present. And I would be even happier if they put this into a newer firmware upgrade (5.xx and 3.xx? 😉) so it doesn't occupy space in storage memory... at least, for 3650 it could be simpler, they put the upgrader release instead of Hantro 2.6
/me really hopes to see this soon 8)
It's offical and here it is.
http://www.nokia.com/nokia/0,5184,5371,00.html
Not sure if it works on 7650 - not tried it yet.
Best
Will 😊
Nice. 😃
But some people wont trust this at all 😃 😉
Sure - look guys there is NO '@' redirector in the url.
See I do have my uses, There is a slight bug, it does not 'automatically' hand over to the player to replay the files.
But you can just go there manually and play your videos..
Best 😊
Will
Update.
The bug is not apparent when installed on the 7650 as the video recorder can play 3gp anyways and does not try to hand over to realone.
Haha - a 3650 program that works better on the 7650!
DOWNLOAD THAT APP NOW! 😃
Hey!... i just test the Video Recorder that is on that link...
said for 3650... but WORK PERFECT ON 7650 TOO!!!!!!!! 😮
EXCELLENT APP!... is the same HANTRO 3.3 app.. but this is 3.4 and
it's FREE!!!! and FREE of that VODAFONE RED BAR at the botton of the video recorder 😃
This is the DEFAULT VideoMMS from NOKIA... PERFECT!.. with sound..
Finally ONE app OFFCIAL from NOKIA to record MMS Videos 😃
the best!
THANKS! FOR THE LINK!!
DOWNLOAD! all you people this NOW!!. i don't care about is for 3650 😃
WORK on my 7650 (3.16) ... perfect!
here is the link just in case:
You can download the Nokia Media Player to play the videos on the PC too... if you don't have Phillips Plataform4 player..
cya! i am very happy now! 😃
so is this the third thread about the same thing then?
