Just thought I would post it again with a clearer topic so that no one will make the same mistake. Druzel and I have expereinced it already.
DO NOT EDIT THE CONTACTS THAT ARE IN(ASSIGNED TO) YOUR SPEED DIAL because it will lock up that speed dial location and the contact assigned to it and not allow you to add any other contact on that loaction anymore. It wil also lock up that contact on your address book. You will not be able to edit nor delete that contact anymore.
SOLUTION: System restore or reformat...
A glitch that everyone should know!
Thanks, I will remember 😉
mine is OK with this actually.
I have edited a few contacts, and it just clears the speedial slot back to empty.
Maybe we have different software versions????
Stu
Mine also just empties the speed dial slot.
[quote="Anonymous"]mine is OK with this actually.
Stu[/quote]
Yes it clears the slot, buy can you try adding someone on the slot again? Or deleting/editing the name you just deted?
works fine with mine SE.
done it several times and no problems
muh
[quote="Muzikfreakah"][quote="Anonymous"]mine is OK with this actually.
Stu[/quote]
Yes it clears the slot, buy can you try adding someone on the slot again? Or deleting/editing the name you just deted?[/quote]
I was the second guest poster I have now registered. 😃
I can add the contacts to speed dial again just fine
Phone firmware is R1D and organiser is R1G05
Just checked my fone and everything seems to be ok. My firmware is also R1D
