I have a Nokia N85 and the firmware is 11.047.
There is chat all over the internet about version 20.175 and 30.019 but I can't seem to find it ??
The software updater on my handset says I'm up to date. When I check on the Nokia website here..
http://www.nokia.co.uk/get-support-and-software/download-software/device-software-update/can-i-update#
it tells me that 11.047 is the newest. How can it be the newest if there are people out there with 20.175 and 30.019??
Any ideas?
Thanks.
Whats your product code whats your network branding they have probably not approved the newest software, find the normal uk product code for your phone and use NSS and chnage the porduct code there are many tutorials on google it takes around 2 mins
My product code is 0574617 and it's from Vodaphone.
Thanks for the reply , I'll go have a look .
This worked great . I had no idea about product codes.
Thanks.
Only thing is dont take it to a nokia care point as if they see you have a diffrent product code they wont help you as this invalidates your warrenty but only if its software related.
