Was just thinking (dangerous I know) - if you do a hard reset, it doesn't wipe mass storage does it?
This being the case, what happens to all your apps? I presume that all the shortcuts to the apps will not be there when you re-boot, yet the data for the apps will still be lurking in the background?
Also, when I do a backup, I don't select mass storage beucase although this is where my messages and apps are, all my music is there too and it would make a really huge backup file. But, assuming Mass Stoagre doesn't get wiped, and the restore brings back all the shortcuts, all should be good shouldn't it?
yup. hard reset formats the c drive only
I had to do a hard reset this morning because I didn't have a backup and after carrying out V12 update lost all connections:icon13:
My mass drive seems to be as it were after the reset.
Did you have apps on Mass? Are they still there?
relax 😊 everything will still be there
So, after a reset the phone scans Mass for apps and puts the icons back in place?
after you do the restore, yes
1. PC Suite -> Phone backup
2. 7370
3. initial configuration
4. restore from backup
5. your icons should be back where they are*
*you must know however, not all programs may work, post restore..
jerm wrote:after you do the restore, yes1. PC Suite -> Phone backup
2. 7370
Ok, that makes sense. Even though I've not backed up Mass, because it's not wiped during the reset, the restore of C should* put everything back like it was. :icon14:
Cheers!!
I am not sure if it is wise to restore from a backup in this situation..
Why did you hard reset in the first place?
If you hard reset because of problems with some previously installed software, then a restore may actually bring back the issue. If this is the case, make sure you restore only certain elements such as your phone book/messages etc and not the applications or phone data (which you can do separately yourself anyway).
I had a major issue before with booting and got to a stage where a hard reset didnt fix the issue and found that the apps that was installed on E got reinstalled automatically by default (which is a feature of S60 that tries to reinstall previous applications from left over data). I ended up formating the E: Drive and restoring some basic stuff before hard resetting it once more..
I've not actually reset, I was just wondering what would happen if I did in case when I next do a firmware update (if one ever comes out again) it all goes wrong!
Thanks for the replies 😊
