Symbianware has released update to award winning compression program Stacker. It is now in version 3.00. Buy it from Handango
Stacker is the best, fully automatized and reliable compression system for your device. Stacker software doubles the size of your entire drives and works invisible behind the scene. When you start an application it becomes decompressed in background automatically and it becomes compressed again when you close it.
Stacker is the best way to increase disks space on your device, it guarantees to give you as much disk space as possible without even thinking about it!
Changes in Stacker Version 3.00
- Has been tested and is fully compatible with Nokia 3650 as well as with Nokia 7650!
- Compact Contacts Database was added. What is this for? Stacker can compact contacts database by removing unused blocks in its files (defragging). Compacting will not only save some space on disk it will even speed up working with your contacts!
- Compact memory command was added. It will reclaim some executable memory from system.
Price: $9.95
Trial: Yes
JyriK
