E52 3g concern!!!!!
3 replies · 3,789 views · Started 02 October 2009
hi there,
i am from Toronto, Canada
i got my e52 and i LOVE it
had it for 4 days and not a SINGLE problem
its e52-1 and made in Finland
anyways on with the problem.
i had 3g phones before, nokia to be specific (5800, n79 etc)
all were on 3g network and it'll even show under the signal meter
but this phone is not on 3g, neither does it show under the signal meter
i called rogers and nokia canada both.
nokia said to call rogers because the service is from their end
i called rogers (my service provider) and i was given the APN address, username, password (access point network)
it asked for pin 2 i got from rogers, i entered and the lady said to put internet.com and it should work, i hung up with her, turned the phone out, took the sim out and put everything back together
turned it on and it wouldn't go on 3g still...
any help would be GREATLY appreciated guys!!!!
thanks
You won't get 3G on the E52-1 in Canada as it doesn't support the necessary 3G bands. The best you'll get is edge.
