How to disable i8910's shutter sound?
Did you try Silent Profile allready ?
😊 Regards jApi NL
jApi NL wrote:Did you try Silent Profile allready ?😊 Regards jApi NL
This is not workable.
Hi - NB I am using xxII1 firmware now, but as far as I can remember, it's the same for the other firmwares I've used:
Start the Camera application (the option you are looking for is in the Camera app itself)
Bottom left of the main Camera app screen is a little 'cog' or settings icon (Cog = as in gear i.e. what you would find in a car's gearbox);
Now, notice that to the right of the Settings word, there are two tabs, one has a Camera icon on it, the other has another 'cog' icon.
Tap the Cog icon and go to page 2/2
there is now an option called 'Shutter sound'
there are 3 types of sound you can choose, the 4th type being 'OFF'
Choose OFF and you are done!
:icon14:
rleader wrote:Hi - NB I am using xxII1 firmware now, but as far as I can remember, it's the same for the other firmwares I've used:Start the Camera application (the option you are looking for is in the Camera app itself)
there are 3 types of sound you can choose, the 4th type being 'OFF'Choose OFF and you are done!
:icon14:
Not that easy. I am using II2. No such option. that's why I ask here, hope someone knows where is the config file and how to modify it in order to disable the camera shutter sound.
