Be first to test a new File via SMS sending software and service!
1 replies · 7,351 views · Started 02 October 2009
Beta-Testers needed for File via SMS sending software and service
SMSMyFile is a free file-sending hosting service. It features a new and original concept of sending files via SMS to other mobile users.
Be one of the first to join a beta-test group and feel free to post bugs, suggestions or comments here on forum.
N E W S !
Added support for Nokia N900 Maemo :icon14:
SMSMyFile client for Nokia N900 Maemo can be downloaded from www.smsmyfile.com
THE ADVANTAGES:
- Send full-size pictures and videos, any type of data, audio, programs etc. to mobile or PC
- You dont need to set up an email connection and are not limited to MMS, Bluetooth or infrared connectivity restrictions
- Service and software is completely free of charge, the only costs are your regular carrier charges for SMS and data sending
- Supports all the latest Mobile platforms - Symbian, Windows Mobile, iPhone, Android, Palm Pre - WebOS, Blackberry, JAVA Mobile.
- Data can be sent as a link to recipient's email on PC and then downloaded at no cost
PLEASE NOTE:
- The uploads are currently limited to a maximum file-size of 10MB per upload
- The person receiving will be be charged only for data transfer, with no charge when using a WiFi connection
DOWNLOAD AND INSTALL LATEST VERSION FROM YOUR PHONE INTERNET BROWSER.
Navigate to www.smsmyfile.com and click on "Download mobile version" it will initiate installation directly to your phone.
MOBILE VERSION INSTRUCTIONS:
- After installation, locate the software icon in your Applications folder by the name: "SMSMyFile“
- Click on the icon and the main application screen will be displayed
- You will see 2 edit boxes, one for the recipient's number and the other one for their email
- You can enter the recipient's number or their email manually in the appropriate boxes OR you can click on OPTIONS and select "Add from Contacts“.
- After you have entered the required data, click on OPTIONS again and select CONTINUE
- Below the number you'll see a box in which a message to the recipient may be added, if you wish.
- This message will appear to the recipient, along with the file link.
- The next step is to choose the file that you wish to send, using the built-in File Manager to do so.
- Select the file and click on 'Upload'....
... you can also send a file to email like this:
Thank you for joining our beta-testing!
Best Regards
SMSMyFile Team
www.SMSMyFile.com
