The N93i has the (exactly) same CPU and Ram as the original Nokia N95---So is it possible for N93i to run symbian9.2, s60v3 FP1---OS of N95?
If so, N93i would have support for SDHC, better RAM, support for widget, ovi maps---everything N95 can do, they have the same hardware.
Can I do it this way: If I extrect some (unique) files from N93i rom (fw 3.0), i.e the camera app, cuiphone(the process for rotating the screen when twisting), setting ect. Then put it in N95 v2.0 fm, and use phenex refresh it on N93i??
or is there any better solutions? Or use rom-patcher? I need some advice...
Thank you! !
