Hi all,
Could do with a quick response please as off on holidays and could do with this before I leave 8shouldnt have left it so late, i know!)
Is there software available that will resize images on the N95? Ideally I need something that will provide the option to resize to a certain size and output them to a different folder??
Havent really seen anythign out there, so though i'd ask here.
Thanks in advance!
It's not exactly clear what you want , probably downsizing ? My solution is using an old Nokia 9500 , with image editor for precise pixeling . Another way to downsize a large image (> 100kB or more) to approx 30kB is using Screensnap (or Screenshot) :
-- Screensnap (set clock back to 2006 aug 06 , just for enabeling installing)
http://www.terramobilis.com/
-- Screenshot
http://www.antonypranata.com/screenshot
(Sub)Folders you can make with Filemanager . Files can be moved to any Folder ( use # + Dpad for marking ) . Also you can make Folders in Gallery .
😊 Regards jApi NL
you can use the N95 built-in image editing picture to crop a pic.
- open a picture from image gallery
- option -> edit
- (in the edit window) option -> apply effect
- click the middle icon ('crop'😉
crop away 😊
you can't save the edit to another folder automatically...but, just use your file manager (y-browser, etc.) to save it wherever you want on your phone
HTH
