Volume control app for n82
2 replies · 14,738 views · Started 05 October 2009
Is there an app that I can use to control the volume of my music player? The manual volume control buttons for my N82 doesn't work anymore and I really don't have the money to have it repaired so I was hoping that there is an app for this. A 3rd party music player with volume control is also acceptable.
It depends on how you like to play your audio files . X-Plore is a free (non-limited trial) Filemanager . With own photo , video viewer and audioplayer . Every file must be selected manually , but the audio is controlled by the D-Pad . Give it a try :
http://www.lonelycatgames.com/?app=xplore
😊 Regards jApi NL
jApi NL wrote:It depends on how you like to play your audio files . X-Plore is a free (non-limited trial) Filemanager . With own photo , video viewer and audioplayer . Every file must be selected manually , but the audio is controlled by the D-Pad . Give it a try :
😊 Regards jApi NL
Hi
You gave wonderful info and I have one doubt , please clarify this ...Is N82 and N81 features same ?
