Is it possible to get the standby home screen to show calendar events from more than one day in the future?
I used to have my phone set like this and it showed approx a week ahead (depending on how many events I had in the calendar etc) but after upgrading the software yesterday I can't find the option to change this.
Please can anyone help? Thanks, it's driving me mad so I would really appreciate it.
I don't own a N96 , so this is a try . Did you check : Menu > Instr > Settings > General > Personally > Stdby Mode > Active Standby > Options ? I know it's a mouthfull , but might help .
😊 Regards jApi NL
Hi there and thanks.
On the N96 I thought it would be under '...Standby Mode > Standby Theme...' but when you get in that menu there are no 'options' to change the settings.
There are options to change the shortcut options - but that's different I think to the standby display screen.
