Correct European 2-Pin Charger ???
2 replies · 3,190 views · Started 06 October 2009
Could someone please kindly positively confirm which is the correct Continental 2- (round) pin charger to use with the 5800.
On the face of it, I thought that it was the ACP-12E, however, it doesn't appear listed on the Nokia website. Perhaps it is just a regional thing.
Any advice would be gratefully received.
Oldsilverfox.
Many thanks for your help.
I can now see from your kind reference that in the Netherlands, the 5800 is supplied with an AC-8 charger, and that this is the generic model.
I now think that it is necessary to add the suffix for the power plug dependent on the region ,
i.e. AC-8X for a UK 13A three pin
AC-8E for a continental two round pin etc.
Thank you again
Oldsilverfox.
