How to send real audio to RealOne
1 replies · 2,450 views · Started 11 March 2003
When I send video files (*.avi) with PCsuite to 3650 it converts them to *.3gp, MP3's are converted to *.wav (poor quality). But real audio files are not converted and they don't play. I suppose that they should also be converted to *.3gp or some similar format. I read that RealOne mobile supports real audio and real video, so how to send real audio files to RealOne, anyone has experience?
Yes this is true, PC Suite does not convert .ra files as reaolone supports those naitivly.
Trouble is if you send it a .ra file at the wrong bitrate or screensize I've noticed realone can have trouble playing them - PC Suite needs to be checking the the .ra file is of the correct screen size and bitrate before letting it thru and resize etc if needed.
It can help if you turn 'performance' to 'off' but not always.
Maybe on the next release..
