I have a Nokia N96. Every time i open an application which requires internet usage, I get prompted for permission for the net. Is there anything I can do so that it always just connects without asking?
Ideally, I'd like it to first check for wi-fi first and then connect to 3 but if that isn't possible then just anything to stop it from asking me every single time would be awesome....
Many thanks
Rab
A suggestion that might work , but I didn't try myself : I set my browser's accesspoint to "always ask" . Web > Options > Accesspoint . The other option is to set it to an user defined accesspoint .
Now with the freeware Birdstep's SmartConnect you can make a group of accesspoints easily . Give this group a name and the group can be used as a single accesspoint .
Could give it a try .....
http://www.birdstep.com/Products/Birdstep/SmartConnect/
😊 Regards jApi NL
