NiceAlarm - is renewed.
NiceAlarm is an alarm management utility for Symbian Os smartphones.
NiceAlarm 1.7 is a powerful and easy-to-use Symbian Os S60 alarm. With it you can select any music tone for every alarm you setup, specify deactivation code to avoid oversleeping, personalize iteration quantity and timeout, add alarm text notes, adjust notification and even more! Don't miss this pretty wake up helper.
Main functions of the application are:
* Six alarm types;
* Alarms filtering;
* Vibration option;
* Touch screen support
* Sound folders selection;
* Standard/Stand-by alarms;
* Alarm text messages support;
* Extended customization options;
* Alarm optional deactivation code support;
* Minimal server part among similar applications;
* Extended sound support (tone selection/random tone).
