screen lock on/off 3rd party software P800 without flip
5 replies · 4,184 views · Started 11 March 2003
I use the P800 excusively without the flip.
i find that sometime text has been added to a diary entry, a call has been made by mistake etc while the phone is in my pocket.
I dont like the virtual flip
Also the screen saver can only become active after 1 min
What would be IDEAL for me would be a screenlock that runs in the background
Clicking on a small 1 or 2 sq mm area in the very botton middle of the screen (say a little box) would either turn on or off the screen lock AND WOULD also would end a call.
Please could someone maKe this app.....I will pay for it!
thanks
N
I ment to add also, one cick on the screen would return to the last open app say Handy Day (but for view only) a futher click in the box would undo lock.
Hey guest,
can you not live with using the jog dial to lock the screen? If you pull it forward and then press it in it should lock the screen with virtual flip. I tried it earlier and it worked a charm.
Z.
Thanks for the tip, but I'm not the greatest fan of the virtual flip
