using the N97 with a PDA
3 replies · 1,910 views · Started 10 October 2009
Hi all,
this may be a strange question considering the N97 does pretty much everything. But I need it to run flash which it doesnt so I was trying to get around this via my Ipaq.
Is there a way to connect the 2 via bluetooth and use the internet connection from the N97 so the Ipaq can get online? It is a ipaq h4150.
any help would be appreciated.
thank you!
Does the Ipaq have wifi? If so you can run Joikuspot on the N97, which then turns the phone into a wifi hotspot allowing any other external device to access the internet.
Just make sure you get a 3G signal when on Joikuspot, otherwise the browing will be very slow. Otherwise, it's great, I use it all the time.
