My 9210 thinks it is an iPAQ!
5 replies · 2,147 views · Started 23 April 2002
I have a spec of dust behind the screen on the phone-side (the PDA side is fine).
Anyone else had this?
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Yup, have that too. In my case, it was caused by a less-than-careful service center when they were fixing a keypad problem for me. I swear there's a hair in there somewhere too...ugh!
ONE spec of dust? I have enough building materials for a birds nest behind mine after a service centre upgrade...
Arild
Arild
Haha...... User posted image
Are the service centres in the UK that bad? Sounds like they're staffed by a bunch of hamfisted goons!
But then again, here in Malaysia, a friend of mine had the case of his 9210 damaged when his screen was replaced....they must have used a screwdriver to pry the case open! Sigh...
Indeed, there are areas in the sahara with less dus than there is in my 9210! It's not an unfamiliar aspect of Nokia phones! I've had it with my 8110i and an 6210!
I always it around in the pocket of my pants, that's probably why. I've had problems with humidity as well, on a warm day little drops of water form on the screen as well!
Best regards,
Teun
