I noticed that the P800 doesn't switch the display off (only the backlight off) when it is plugged into a charger.
Does anyone know if it is possible to change other things whilst it is on charge? - Most specifically, to get it to turn bluetooth on whilst it is charging?!!! - It zaps the battery otherwise, and is a bit annoying you can turn it off.
I do also miss things like the 'meeting' profiles.
PS. Why when I have bluetooth enabled, and the bluetooth headset on (Bluetake BT 400), does the phone not think it's in handsfree/headset mode? - It means that I can't use voice dialling with the headset 😞
