Pocket Cook for the P800 is a MobileVB program that acts as a recipe database. The software has upto 4000 recipes available for dwonload and has search and shopping list functions.
This is one of the best MobileVB powered program available. This si exactly the sort of thing that MobileVB is good for - converting relatively simple function apps to the P800 from other platforms. However just because its simple (the idea of a recipe book is not new) it does not means its good. While some MobileVB apps leave a lot to be desired in function and price this is a genuinely useful program and a must for any cooking fan.
The software is available via Handango and the authors website.
Author Notes:
Turn your P800 SmartPhone into your cooking companion. Wherever you are, you can choose what to cook, easily create a shopping list of what you need to buy, and even plan menus for the weeks or months ahead. Comes with 4000 recipes and a powerful search engine to find just those recipes you are looking for.
4000 recipes available for download at no extra charge.
Organise your life with the Menu Planner and Shopping List features.
Add your own recipes, or edit the provided ones.
Automatically calculates ingredient quantities based on number of servings that you can specify. No more calculators in the kitchen.
US or Metric measurements - choose the format when you download one of our free recipe packages.
Nutritional analysis of every provided recipe, so you know what you are eating.
Very fast keyword searching. Type in a word and all recipes containing that word are displayed.
Take your P800 shopping, and tick off your purchases as you make them. The items in the list are generated automatically from the recipes, or add your own as well.
Make up a Menu plan for the coming week or month, and then quickly locate all the chosen recipes with a quick click.
Palm and Pocket PC versions also available.
A PC based companion is planned for mid 2003 allowing recipes to be entered on your PC, and millions to be imported from sources all over the web.
This product requires Appforge Booster for P800 available from www.appforge.com/booster.html
A full Acrobat Reader format manual (pdf) is available for download from the URL below.
Further information at www.pocket-cook.com/p800
