Does anyone know how I can disable the vibration when you lock or unlock the phone? For some reason it really irritates me :redface:
Turning vibration off via the profiles menu disables vibration for text and phone calls aswell afaik. But I need to keep that on!
I know that when you have the phone on silent, the vibration is off too.
Not sure what stops it from vibrating though.
I agree sometimes find it annoying too, and find that the main cause for the lock/disable switch not working properly is down to the vibration feedback because when I had it on silent on v11 it worked perfectly all the time.
