Unable to stream audio/video in Nokia e62 ***Plz HELP***
3 replies · 12,151 views · Started 14 October 2009
i have
Nokia e62
V 2.0618.06.17
10-08-06
RM-88
having inbuilt
RealPlayer
V s60.30.20.01 A
18-May-2006_13:01:35
loop- On
use Proxy- No
default access point- bsnl_west_gprs
online time- unlimited
lowest UDP port- 6970
Highest UDP port- 32000
GPRS bandwidth- 28.14kbps
EGPRS bandwidth- 65.28kbps
and i am using
bsnl internet connection (Maharashtra, INDIA)
setting name- bsnl_west_gprs
data bearer- Packet Data
apn- grrswest.cellone.in
authentication- Normal
n/w type- IPv4
phon IP- Automatic
D add- Automatic
Proxy serv. add- none
Proxy Port no.- 0
i unable to stream bbc radio (bbcradio.mobi or any radio station like m.youtube.in, www.onlinefmradio.in, etc.
plz send me the process to do so.
when i open bbcradio.mobi > BBC radio1 > it download the file named as 'r1.ram' > open > realplayer will open > after the 3 second of 'connecting' process bar the 'loading' process bar will start for 5-6 second > then their is error msg like "Unable to connect server. Server time-out"
But when i use internet by connecting my mobile(as a modem) to the computer then... there is no such problem....alll sites working weelll.
plz send me the process to do stream on my Nokia e62 handset. And gave me other links of online radio and online videos...
plz reply here as soon as possible
Thanks!!!
Have a look here : Menu > Media > RealPlayer > Launch > Options > Settings > Streaming > Network > Default Access Point .
You can select the correct accesspoint here .
Edit : sorry , seems like you selected the right accesspoint . Don't know a solution really ......
:😊 Regards jApi NL
RealPlayer on E62 is a non-starter. I have yet to find anything it will play, and I've had the phone for four years.
I loaded something called S60 Internet Radio Player (it was so long ago I can't remember where I found it) and it works great. You'll need some other apps with it, but look around, you'll find it.
Good luck, if I find more I'll post back,
Geoff.
