Suggestion for Domi(fexplorer) / Ximplify(seleq)
2 replies · 2,829 views · Started 12 March 2003
A few suggestions which I feel would complete these programs:
1) a 'Set as desktop wallpaper' function, I thought seleq had this, but it only sets the backgrouns within seleq 😞 (and also a set as oplogo added to fexplorer)
2) ability to scroll through images within a directory - at present you have to 'view' each image, then exit and 'view' the next image. Would it be possible to use the joystick up/down (or left/right) to view the next image? (same way as built in image viewer works).
3) When I 'copy' a file then try to paste it but am unable to do so (for one reason or another), if I want to paste the file somewhere else, I am forced to find the original and select 'copy' again. Can this be fixed? (perhaps even an indicator to say there is something in the clipboard?)
4) In seleq, if there is a folder highlighted and I chose 'paste' the file is put into the highlighted folder, in fexplorer the file is put into the current folder. I'd like the option of being able to do one or the other - ie if a folder is highlighted and I chose 'paste' give me the option of pasting into the highlighted folder, or the current folder.
5) I often want to make a copy of the same file in the same folder. To do this is tedious: I have to copy the file out of the folder, rename it, cut it and paste it back in. I'd like the same functionality as windows, where if the file exists, the pasted version becomes 'copy of <filename>' or it asks if I want to overwrite the original.
6) (Fexplorer only) Is it possible to display the file size beside the file name (same as seleq and filebrowser in stacker) 😊
I'm being picky I know, but these are kinda annoying to have missing 😊
Thanks a lot for taking a bit of your time to write this message :P .
I put your suggestions in my to-do list 😉 .
Dominique HUGO.
FExplorer.
