hi everyone
i want to copy some files to drive:z
but i cant.
i've already tried:modo,y-browser,and x-plore.but noun of them did the trick.
please guys,help me find a software that can do it. please guys,help me
thanx
how to copy files to drive:z
No can do. The Z-drive is ROM - Read-Only Memory.
Only way to modify is to modify the firmware sources, rebuild the firmware and reflash the phone with the new firmware.
roostaamir wrote:hi everyone
but i cant.
thanx
Why would you want to? If you could somehow increase the Z: drive to fit other stuff in, you'll lose the same amount from C: - THEY'RE ON THE SAME CHIP!!!
Hello roostaamiz.
I read your entire post and problem just do the right click on Z drive and select the explore then open the drive then do the your work the second option is that command prompt.
Thanks.
yes your idea is imposibble ....but why you want copy your file to folder :Z ...
it will causes your phone run slowly
