Song detect software
2 replies · 4,481 views · Started 15 October 2009
Hi all,
What was the name of that software that you can use on your mobile phone that detects the name of artist and song by sampling a bit of it? And where is it available?
I heard this software you can install on the iPhone/iPod . After recording it will connect to iTunes to buy the file . I believe there is also software like this for Windows Mobile .
Since Nokia runs a music store as well , I'm pretty sure an App like that will be introduced for Symbian . Anyway an updated documentary server and internetconnection is needed .
😊 Regards jApi NL
hey Gavin
It's called Shazam and you can get it from Ovi store. It works really well too.
Hope this helps.
