help on bt
6 replies · 1,410 views · Started 12 March 2003
i got a bt
it can connect o nokia suit
it can transfer file from comp to phone
but when i try to transfer from phone to comp is cannot work why?
There is a huge thread on here somewhere about this very error - sometimes you can be lucky and change a registry setting and it works.
I just use PCSuite & Filemanager from Epochware - transfer your images without even getting your phone out you pocket - much better solution than sending from the phone anyways 😊
Have a search 😊
Good luck!
[quote="Darockz"]i got a bt
but when i try to transfer from phone to comp is cannot work why?[/quote]
The problem might be that Mrouter doesn't share BT link.
Solution Take PC Suite out of startup directory. Reboot. Activate BT on cellphone. Run software that came with BT. Should be able to send from phone to PC. File should be in BT outbox. Only run PC Suite when you want to use it, but you must reboot if you want to return to sending from phone to remove MRouter from memory.
