Which compresses better?..nuff said!
stacker vs sdoubler.
stacker.
(alltought theyre using the same freakin ZIP methods in packing just DONT USE SDOUBLER. Want to know why? lolz. Just install SDoubler and see what i mean. (shitty-code,2manySystemErrors)
STACKER! KING OF 7650 APPLICATIONS!
BUY IT! The Stacker coders simply deserve it!
8)
Well, I uninstalled Sdoubler yesterday & installed Stacker, to try it out
I like the "one stop shop" of compress contacts and compress memory, although the utilities Nameswap & Memory already do this.
Stacker is more visual, you can see the un/compressing progess better, but I think Sdoubler is slightly quicker. (both PsiNT & Symbianware clain their software is faster & compresses better...) Sdoubler has more options for compressing & uncompressing
Also, I much prefer the free memory display of Sdoubler, and the ability to work with java apps and messages.
Lastly, I have never had system errors with Sdoubler, but 3 times now I have had a system error with Stacker whilst refreshing after compressing a file, which was impossible to stop (had to exit to the phone's menu)
So for stability & look and feel, I go for Sdoubler (since I haven't done a benchmarking on compression ratios and times, I think they are broadly similar).
Paul
stacker!! this topic is discuss long time ago 8)
HI!..
I am not sure about this...
i tested Stacker 3 and SDoubler 1.40...
SDoubler look faster... and no ERRORs...
and SDoubler have the PACK and UNPACK ALL APPS... that's is usefull..
STACKER don't have that option...
and it's faster to EXIT from SDoubler with one softkey at right.. EXIT..
than use the menu and go to the last option QUIT like STACKER...
little details but SDobuler look more intuitive ...
The Browser on Stacker i don't use it too much.. because i don't compress things that can't be compressed too much, so this option means more MEM space for stacker...
SDoubler use less mem space installed (if you use PSILOC libs for other apps you save more mem with sdoubler)
Anyway.. i use SDoubler 1.40 by now... i think that Stacker have more publicity and more people talking about that app.. but SDoubler it's very good too.. and to me.. is more efficient and faster..
sorry Stacker fans.. 😉
cya! 😃
[quote="IRVING02"]stacker!! this topic is discuss long time ago 8)[/quote]
I also vote for sdoubler. I find it a lot smoother to use. I've tried stacker 3.0 and still find SDoubler to be my choice.
i use both but i prefer stacker
stacker allows u to do sumthing else while its stacking while s dbouble takes ages to pack
HI!...
SDoubler it's multitasking too while is packing... and/or unpacking
and you don't mention the long time REFRESHING the APP LIST on STACKER...
SDoubler refresh the app list faster..
anyway...
i preffer SDoubler...
cya!
[quote="Htsangers"]i use both but i prefer stacker
stacker allows u to do sumthing else while its stacking while s dbouble takes ages to pack[/quote]
If you change settings in Sdoubler to Multasking on start and exit, you can also carry on using phone. Sdoubler definately is much quicker than stacker and also less buggy. Stacker gives higher compression, but not much difference.
[quote="Doc"][quote="IRVING02"]stacker!! this topic is discuss long time ago 8)[/quote]
I also vote for sdoubler. I find it a lot smoother to use. I've tried stacker 3.0 and still find SDoubler to be my choice.[/quote]
i guess we should use both of them!!! 😃 😃
Which one compresses your apps if you installed both? Which is the master? Stacker compressed sdoubler? or sdoubler compressed stacker?
[quote="Anonymous"]
Which one compresses your apps if you installed both? Which is the master? Stacker compressed sdoubler? or sdoubler compressed stacker?[/quote]
sdoubler compressed stacker,i think thats the best combo 😃 😃
yup agree with you irving ihave sdoubler compress stacker as i only use stacker to compress contact memory ... other than that use sdoubler hehe 😃
u r all lucky that u can afford to buy 2 applications with the same functions
i dont find that a wise move unless you get the apps for free or if you are a beta-testers that has the priveledge of getting a license or registration code from the developers.
two thumbs up!! 😃 😃
never mind wot i sed stacker better, sboubler just put a system error into ma RallyX now have to reinstall and lose records :'(
S T A C K E R gets my vote. Very fine product 8)
I've have had some problems whit sDoubler, couple of strange errors and its enough... And Stacker doesn't ever prompt any errors! So my vote is STACKER. I appreciate stability very much!
HI!...
To me..
Stacker 3.. no errors... SDoubler 1.40 no errors
SDoubler... faster...
i use SDoubler...
cya! 😃
Why get yourselves into trouble?
I don't use 7650.
I've tried the phone and found that it doesn't not help me but keep me busy & cause trouble.
I will stick back to those handset customized OS phone other than Series60.
Until one has come out a better design of the Series60 phone.
I think somebody have to improve the design of the Series60.
[quote="kat-kat"]Why get yourselves into trouble?
I don't use 7650.
I think somebody have to improve the design of the Series60.[/quote]
which phone might that be?
I thought that all phones are like women. Lovely to play with but lots of trouble and never does what they supposed too. :black:
[quote="kat kat"]Why get yourselves into trouble?
I don't use 7650.
I've tried the phone and found that it doesn't not help me but keep me busy & cause trouble. [/quote]
For sure the, 7650 is aimed at the tech savy consumer, perhaps a 3310 would suit you better? 😃
The 7650 causes me no trouble, and along with being a phone it helps keep me organised, and occupied if I ever get bored.
how do i upgrade my old stacker to stacker 3.0?
TIA
just download the new version (Stacker 3.00) from http://www.symbianware.com/download.php?id=stacker60&lang=en&pl=all&s=0 and install it. It will replace your old version[/url]
HI!...
that is true..
it replace the old version.. but with a 3.0 TRIAL version :-?
that is not a good upgrade 😃
cya! 😃
hmmmm what happened to our registration? not free upgrade?
[quote="AEFOX"]HI!...
[/quote]
Only if the previous version installed on your device was cracked :evil:
because the installation substitutes cracked file with newer and original one.
There is no upgrade for cracked versions 😃 😃
[quote="f1gpshop"]hmmmm what happened to our registration? not free upgrade?[/quote]
Stacker's upgrade is free, like upgrades for our all applications.
So, you need to download and simply install the newer version over the old one only. If your version is registered it won't ask for registration again and will keep your old reg. info.
that is true..
cya! 😃[/quote]
sheesh... that is of course will happen if you are not a registered user.
hahahaha! its obvious that you are using a cracked version of Stacker 2.06 😃 😃
P.s. 2 AEFOX
Nothing personal, and I really don't care which version you use or don't use. Only one point to highlight: if you have problem with CRACKED version it doesn't mean that the original version is crappy, and please don't make it as your argument and please don't write our support about it!
Need support? Then write atzplzw, Phantasm, etc
P.p.s. in cracked version of Stacker Phantasm forgot to include to installation file:
1. Device identification id - installation will say that the application is not compartible with your phone.
2. Some scripts that are executed during the installation of original version!!!! Phantasm included only files. => In some situations the application won't be installed correctly (especially if you doing upgrade)!
3. Installation was not signed
GUYS, PLEASE DON'T WRITE OUR SUPPORT ABOUT THESE PROBLEMS!!!!!!!!!!!!!!!!
WE DON'T SUPPORT WAREZ VERSIONS!!!!!!!!!
That is why some crack users are I.D.I.O.T.
When they want to upgrade they must install an upgrade crack, not the upgrade from the developer
sheeesh AEFOX ... still you have the face to write "that is not a good upgrade" ... :black:
