n97 Windsreen Mount Holder
15 replies · 6,622 views · Started 17 October 2009
Why have you ordered two? Have you got two N97s and are likely to use them both in the car at the same time? 😃
zxon wrote:Why have you ordered two? Have you got two N97s and are likely to use them both in the car at the same time? 😃
Might be in same boat as me, one for the car and one for the van.
My second n97 can back up my first one when the GPS signal is lost on it LMFAO
No.. my mate has a N97 too.
Cheers for the up Dave, I do love the fact that the slider can be opened and also that the camera lens is not obscured.
Yes I have the same one as pictured, fantastic fit and never comes off the windscreen like some of the others I have purchased.
Robski
davecozens wrote:you can do silly things like use qik to stream your driving 😉
Ahh, so that's how Top Gear does it 😉
POWEERRRR!!!!
These look good. I'd consider one but I was bought a TomTom as a "car warming" present.
only problem is that the slide doesnt work when the phone is in.
Troublesome when using something like Garmin (only T9 touch input otherwise since N97 doesnt allow touch keyboard)
Does anyone one know of a mount that can be used if the phone is in a case. Mine is in a crystal case and its a pain in the but to remove each time. Adds about 2-3mm to phones housing.
D4n958GB wrote:Does anyone one know of a mount that can be used if the phone is in a case. Mine is in a crystal case and its a pain in the but to remove each time. Adds about 2-3mm to phones housing.
Kensington do a universal holder with a rigid goose neck, I think they are �20 though, google search it.
Got em this morning, 10 days from purchase date and I have to say these are really good.
I enjoyed using the Ovi Maps on the way home with good signal even though it was laggy with the GPS lock... I need to send my phone into Nokia Service Centre
I'm after a couple of these, but i need one with a long reach, as the windscreen is miles away!
The other can be a short stubby one like those linked to here.
But i would definately like them to allow the phone to be opened!
riverboat wrote:I'm after a couple of these, but i need one with a long reach, as the windscreen is miles away!
http://cgi.ebay.co.uk/CAR-CHARGER-WINDSCREEN-HOLDER-MOUNT-CRADLE-FR-NOKIA-N97_W0QQitemZ370278135021QQcmdZViewItemQQptZUK_MobilePhones_MobilePhoneAccessories_MobilePhoneBatteries?hash=item56364bf4ed
This is the one i've had for 2 months.
