i have a 7650 and i have a infra red port so my phone is attached to my comp. i have hundreds of midis on my comp but dont have a program to transfer them to my phone, and no my 7650 pc suite dosent support it so can anybody recomend a program and a link to download it?
7650 ringtones
Assuming you run Windows, if you activate IR on the phone, "wireless Link" should start on its own (check your desktop), you'll see an icon next to your clock on the bottom right.
Alternatively, go to control panel and it's the last option in the list.
Then just select the files and send them over
Paul
Also assuming your phone is lined up and you have a 'link' you can right click the file on your PC and select 'send to' then 'infared' and away it goes 😊
Best
Will
oh my god!!! i am so grateful thank u so much i was full stressing i couldnt do it, if i lived near u id give ya 50 bucks, thanks!!!
no problem, we all try to help out. you could always post the 50 bucks 😃 😃
Paul
thats of course the best way to do it...
you can also download the software OXYGEN PHONE MANAGER. its an amazing pieces of software.
with thats you can transfer very easily. logos,ringtones, caller groups, op .logos,start up logos.
cheers
HyPeR
[quote="gauravonline"]...you can also download the software OXYGEN PHONE MANAGER. its an amazing pieces of software...[/quote]
So is the 7650 version released?
Seems to be not...
so gauravonline must be a betatester or...
