Slow Internet...is it the phone or the connection?
12 replies · 5,744 views · Started 20 October 2009
I use AT&T's 3.5G network for data connection. Its my first data phone, so I don't have any other experience. I don't know what the problem is, but my connection times out way tooooooo often. Meaning, when it downloads/uploads - its fast enough for me, but frequently it will just stop for 20 seconds and then continue at OK speeds and then stop again. What is going on? I can't even listen through ONE single track with Mobbler without being interruped like 50 times for 15-20 seconds! Is this normal?
Do the signal strength bars (all phones got them) have same effect on data signal strength? Even at all full bars I keep getting this severe network lag.
Any ideas? Could it be the phone? Could it be because I use inside a huge office building? The signal strength bars are always full here...
Bandwidth is directly proportional to the Signal strength.
My advice for a test is to compare the loading of a heavy webpage between 3.5G and a FAST WiFi if you can get access to one. Also try to download a 1MB or so the benchmark between the two.
If there is differences, then it is the 3.5G reception. Dont hold your hopes up - mobile internet is great, but still not as fast as desktops and wont be until we get bigger memory and bigger storage for caches.
there is a few ways to speed it up abit, if you dont realy view flash video sites then in options select to show Images Only, also disable java script for very fast browsing, if you do goto a video site like youtube just pop into the settings and enable java script again (dnt need to enable flash) you just load the page then click on the space where the video shoud be and it will load and play even with flash disabled, it makes browsing faster, my own site takes aroud 7 seconds to load with JS and flash enabled, with them disabled it takes just 3 seconds, try it and see if it works for you.
bchliu wrote:Bandwidth is directly proportional to the Signal strength.
WiFi works fine. See, what I am saying is that my bars are FULL - doesn't that mean that my 3.5G connection has strong signal? Or is that only for conversations?
Also, the speed is OK. Its the time outs that bother me. Even at 10Kbytes/sec it would be fine, but NOT if it just stops in the middle of things! How do I get these 20 second pauses to stop happening? What causes them?
thats just the network, im in UK but iv read that AT&T is huge and i supose it gets over crowded at times
Actually.. Had a thought about it and realise that the new feature of the N97 is the "Internet" Destinations mode that consists of various access points. When accessing the internet, it will search the access points in order before coming to the 3G/HSDPA option.
This means if you are starting a new connection or reconnecting a connection, it will try to search for all this beforehand and can take a few seconds before you get there.
Biggzy wrote:thats just the network, im in UK but iv read that AT&T is huge and i supose it gets over crowded at times
You might be right... Yesterday I rode the bus for 15 minutes and every song on Mobbler was interrupted heavily by long pauses. Today I listened without a single interruption... I guess its the network. What bothers me is not slow speed, but like I said - long pauses in-between slow speeds. Without these pauses I would actually subscribe to Last.fm...
MonarchX wrote:You might be right... Yesterday I rode the bus for 15 minutes and every song on Mobbler was interrupted heavily by long pauses. Today I listened without a single interruption... I guess its the network. What bothers me is not slow speed, but like I said - long pauses in-between slow speeds. Without these pauses I would actually subscribe to Last.fm...
the pauses are prob just the song buffering, this would happen if the network cant keep up with the data then is being transfered to you device via 3G, with so many iPhone users on the network i wouldnt be suprised if it had problems evry now and then with data, i know its annoying but i wouldnt worry about it, i dnt think theres anything you can do.
Biggzy wrote:the pauses are prob just the song buffering, this would happen if the network cant keep up with the data then is being transfered to you device via 3G, with so many iPhone users on the network i wouldnt be suprised if it had problems evry now and then with data, i know its annoying but i wouldnt worry about it, i dnt think theres anything you can do.
But 3G is ALL that I use! I do not use WiFi or any other access points. So, how can it be fast on 3G and then transfer from 3G to...3G and be slow? That made no sense whatsoever.
MonarchX wrote:But 3G is ALL that I use! I do not use WiFi or any other access points. So, how can it be fast on 3G and then transfer from 3G to...3G and be slow? That made no sense whatsoever.
im not sure lol, give AT&T a call, thats what i would do, at the end of the day your paying for 3G and its not good enough as its not doing what its ment to do, sorry i couldnt be moree helpfull
Biggzy wrote:im not sure lol, give AT&T a call, thats what i would do, at the end of the day your paying for 3G and its not good enough as its not doing what its ment to do, sorry i couldnt be moree helpfull
Maybe you meant that these interruptions happen when it uses 3G instead of 3.5G?
MonarchX wrote:Maybe you meant that these interruptions happen when it uses 3G instead of 3.5G?
does it switch alot between 3G and 3.5G? If so then that could be the problem.
Biggzy wrote:does it switch alot between 3G and 3.5G? If so then that could be the problem.
How can I tell? I know the bars are there for voice signal and always at maximum (all bars). I can never tell if I get good data signal though. There is no indicator. There is just this double arrow thing that says 3.5G on top of it... and it interrupts every 10 seconds for 20 seconds...
